onalswina
Jan 13, 2023Follower
RAX78 AP Mode - Disable DHCP?
I am using my RAX78 in AP mode and I need to disable DHCP. Everything seems to be working fine but I'm told that I should disable (true?). The LAN SETUP option is greyed out under ADVANCED > SETUP > LAN Setup. Does having my router in AP mode automatically disable DHCP or do I need to take me router out of AP Mode, disable DHCP, and then put it back in AP Mode?
I am connected to a CAX30 with Wi-Fi disabled.... THANK YOU!
1 Reply
In AP mode, dhcp is automatically disabled.
Why disable the wifi on the CAX? You could simply put it on a different channel (to prevent interference) and a separate ssid.
Then the devices close to the CAX could be attached to that and the ones closer to the RAX be on it. It'd offload a little burden from the devices and wireless.
