domerdel
Jul 29, 2026Follower
RAX80 - Port Forwarding Triggering List Hidden
Running the latest firmware update V1.0.11.148_1.0.82. I went to my Advanced > Port Forwarding / Triggering page only to find all services are missing as they are no longer listed. I went to add ...
Jul 30, 2026Guru - Experienced User
HappyCat wrote:Make a configuration backup, then do a Factory Reset.
Maybe. But restoring that config might also re-introduce the problem (since it could be caused by a corrupted config).
HappyCat
Jul 30, 2026Luminary
True. Reloading a saved configuration might re-introduce the problem. This would imply that only a full reconfiguration might work. (or, maybe the RAX80 firmware needs to be downgraded.... or......???)
My point is that this is a relatively quick and easy experiment. It takes me almost two hours to do a full Factory Reset on my Orbi system (much of the time correcting numerous typos). Whereas, I have done this "quick reset" in well under ten minutes.
