SweetDrinker
Aug 08, 2020Tutor
RAX80 1.0.3.98_1.0.46 firmware reseting after restart / loss of power.
I have been wanting to use my RAX80 in wirless AP mode and in doing so it needs to reboot to change. When it reboots it factory resets itself. No matter what i try if the RAX80 losses power it factory resests itself. I do not know if its a firmware problem or a device problem.
- ThalusInitiate
hello,
i have the same issue. It's very ennoying that as soon as I want to activate the AP mode, my rax80 does a factory reset ... this appeared with the latest firmware update (1.0.3.98).
moreover, I cannot update the language of the interface (stay in 1.0.2.76_2.1.46.1).any help will be appreciated.
- Christian_RNETGEAR Employee Retired
Hello,
May you revert to the previous firmware version and let me know if your issue persists.
https://kb.netgear.com/000061902/RAX80-Firmware-Version-1-0-3-88
Christian
- ThalusInitiate
Hello,
I downgraded the firmware but the issue persists.
thanks for the idea - QKingAspirant
Christian_R wrote:Hello,
Christian
I have similar issue, but on V1.0.3.92_1.0.43
Whenever you lose power, the only way to get the router to boot is to press and hold the reset button while booting. Otherwise it will just sit there and not boot, with fans spinning fast. I am scared of losing power, because every single time I have to manually apply settings.
Reaaaaaaallly want a firmware that can 1) boot reliably 2) can save settings
Hi QKing - We recently released a new firmware version for the RAX80. Please update to the latest version.
https://kb.netgear.com/000062282/RAX80-Firmware-Version-1-0-3-102
Christian
Hi Thalus,
May you send me a private message with your email, phone, and serial number. I'd like for our support team to reach out for further investigation.
Christian
