mr396
Jan 16, 2019Follower
RAX80 and iTunes server support
How do I enable the RAX80 to be able to be an itunes server? I can not find the check box to activate it in the advanced setting under Media server tab under USB functions.
any help?
michaelkenward
Jan 17, 2019Guru - Experienced User
Do you know that it supports this feature?
There is support for the RAX80, including a manual, at the end of this link:
>>> RAX80 | Product | Support | NETGEAR<<<
The manual says nothing about iTunes.
See the section Specify ReadyDLNA Media Server Settings.
