D-hauser
Aug 26, 2019Aspirant
RAX80 cannot connect to modem
So my internet went down today and it seems that my RAX80 can't connect to my modem. When I directly plug my computer to my modem it works fine but once I put in my router nothing works. I tried resetting both my modem and router and that didn't work. When I check my nighthawk app it says that my device Is offline and I cant access its settings.
Power cuts usually take out both the modem and the router on a network. When the power comes back on, they may start up in the wrong order, with the router starting before the modem is ready. That means that they get confused about which is in charge.
It may help to reboot the whole network in the right order.
Be sure to restart your network in this sequence:- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
- D-hauserAspirantI have that a shot and nothing works, I cant even connect to the wifi. Would performing a factory reset possibly fix my problem?
Who knows? In desperate circumstances, it is always worth a go.
