yashago's avatar
yashago
Guide
Aug 24, 2020
RAX80 date and time issues
My RAX80 runs on firmware v1.0.3.98_1.0.46.
Router status shows time from 14 days ago. reloading page shows the same time plus few seconds but minutes never advance.
NAT was configured to use default NETGEAR time servers, I changed that to use time.google.com and rebooted router.
Correct day and time appeared upon reboot but then the minues would not advance again.
Any suggestions?
    Any suggestions?
    I sent a private message to @Christian_R  with my serial number & email address. I was sent the beta firmware which has solved the NTP Router Time Issue and ipV6 connectivity.
    Any suggestions?
      • yashago's avatar
        yashago
        Guide
        SAM_the_GAM thanks for your advice. I received a beta firmware and it seems that some time issues are resolved and some aren't.
        Logs show correct time now.
        Thanks!
