pjmulvaney's avatar
pjmulvaney
RAX80 device type pick list is blank
RAX 80 Firmware 1.0.1.70_1.0.30
In summary I have close to 30 devices connected, and I want to begin my QoS setup to prioritize some traffic such as my XBOX which tends to lag and disconnect.
Question/Problem:
Under Basic/Attached Devices and I select a device and there is a drop down for "Device Type" that is blank, and the drop down doesnt list anything.  What is that field used for and why is it blank?
Thanks in advance.
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi pjmulvaney,
    If you don't mind, would you provide a screenshot of what you see.
    Thanks,
    Christian
    • JeffMills's avatar
      JeffMills
      I have the same issue.  Nothing shows up in the Device Type drop down.
      Attached is a screen shot that doesn't show much because there isn't much to show.
      I have clicked on the Device Type dropdown and that is what it looks like.
        Christian_R
        Hi JeffMills,
        May you let us know what firmware version your router is on.
        Thanks,
        Christian
