Chris11271984
Jul 06, 2019Guide
RAX80 Disconnecting Hardwired connection only
On FW 1.0.1.58
Just randomly a few times a day anything hardwired to the rax80 will disconnected and then immediately reconnect. Everything connected via wifi stays connected without any interruption. Been extremely disappointed with the RAX80 and just went past my return date. I would gladly taken this one back and gotten my money back. Should of never switched from my x10.
- SAM_the_GAMLuminary
The problem you are describing is currently a bug in 1.0.1.58 firmware. Downgrade to 1.0.1.56 or 1.0.1.40 and the problem goes away. I encountered the same disconnection issue with 1.0.1.58.
- I've downgraded to 1.0.1.40 hopefully no other issues will come up
