Qwikpanda
Jul 31, 2026Aspirant
Rax80 dynamic qos settings
Hello I have a plan for up to 1 gig download speed and 40 upload.what would be the best inputs to add for download and upload speed.i game wired for call of duty.i know they said it is recommended to...
Aug 01, 2026Guru - Experienced User
I would not use QoS. I've not used QoS on my 1G.50Mbs ISP service for years. QoS isn't really needed for these higher ISP services as gaming speeds don't use the max download or up load.
Game all the fine with out it. I find that ethernet connected gaming devices is most recommended for best gaming performances.
- QwikpandaAug 01, 2026Aspirant
Ok..what about disable port scan and ddos protection and sip alg should those be checked or unchecked in box for better gaming performance?
- StephenBAug 01, 2026Guru - Experienced User
Leave that unchecked unless you have a SIP phone that needs it.
It says( disable sip alg )next to the box..I should have it unchecked? And what about (disable port scan and ddos protection) check or uncheck box?
- QwikpandaAug 02, 2026Aspirant
I am wired. I have also other family members that stream off YouTube and play on pc but they are on Wi-Fi.it just feels my shots connect more when I had qos enabled.but I am not sure what would be the correct input for dl speed to put for qos
