Qwikpanda
Jul 31, 2026Aspirant
Rax80 dynamic qos settings
Hello I have a plan for up to 1 gig download speed and 40 upload.what would be the best inputs to add for download and upload speed.i game wired for call of duty.i know they said it is recommended to...
Qwikpanda
Aug 01, 2026Aspirant
Ok..what about disable port scan and ddos protection and sip alg should those be checked or unchecked in box for better gaming performance?
Aug 01, 2026Guru - Experienced User
Qwikpanda wrote:sip alg should those be checked or unchecked in box for better gaming performance?
Leave that unchecked unless you have a SIP phone that needs it.
- QwikpandaAug 01, 2026Aspirant
It says( disable sip alg )next to the box..I should have it unchecked? And what about (disable port scan and ddos protection) check or uncheck box?
