Orbi
Mar 05, 2019Star
RAX80 Firmware V1.0.1.56_1.0.23 needs work!
Not even sure where to post this since my model number is RAX80. Anyway, the QOS sucks, and the DHCP must be screwed on firmware Firmware V1.0.1.56_1.0.23. Or the http interface doesn't update if y...
schumaku
Mar 06, 2019Guru - Experienced User
How comes the RAX80 (AX8) and RAX120 (AX12) are still not available as models to select here on the Nighthawk Routers community section, dear ChristineT ?
Orbi wrote:
Anyway, the QOS sucks, and the DHCP must be screwed on firmware Firmware V1.0.1.56_1.0.23. Or the http interface doesn't update if you hit refresh.
1. If I set QOS to Highest it some how resets for the device and even changes the label i've assigned to it.2. Problems with my smart devices because the iptables must not update correctly for wired devices.
3. Labels assigned with edit button on administration/attached devices wont save for some reason.
Why do I don't wonder for a second? All foir items listed read like a fil-rouge of random issues Netgear has with many different consumer routers for a longer time - not to much specific to the RAX80 (AX8). Issues come and go and return with firmware updates. Worst firmware quality in the consumer router market - not acceptable for expensive leading edge Nighthawk routers. Return it, and post negative feedback. Otherwise Netgear will never wake up.
Altsai Christian_R make this consumer business unit do a proper job! It's just beyond of just ridiculous.
