Orbi
Mar 05, 2019Star
RAX80 Firmware V1.0.1.56_1.0.23 needs work!
Not even sure where to post this since my model number is RAX80. Anyway, the QOS sucks, and the DHCP must be screwed on firmware Firmware V1.0.1.56_1.0.23. Or the http interface doesn't update if y...
Christian_R
Apr 08, 2019NETGEAR Employee Retired
Hello necrocis - Have you contacted support regarding your issue?
https://www.netgear.com/support/default.aspx
~Christian
BubbleCat
Apr 09, 2019Star
Just created an account to chime in here:
I bought my RAX80 about a month and a half ago. Things have been mostly, OK. I updated to the most recent firmware here, and have had constant disconnects. The router lights show connected to internet, but none of my devices can connect to the wireless network, and my wired connections are dropped entirely.
Pretty let down so far for a $400 router :/
- rob114Jun 16, 2019Aspirant
I have same problem and i have ugraded to new firmware it drops out every 2 days and needs to be disconnected to reboot this really sucks for a wifi router this expensive too late to return and buy something that works if it is firmware someone should be able to fix or is it just a company who doest care what they put out to consumers.I know new firmware has their problems but to not be able to stay coonected is really poor start and really puts sour taste in my mouth and if hardware fix it ,i notice a lot of others seems to be experiencing same problem
