Orbi
Mar 05, 2019Star
RAX80 Firmware V1.0.1.56_1.0.23 needs work!
Not even sure where to post this since my model number is RAX80. Anyway, the QOS sucks, and the DHCP must be screwed on firmware Firmware V1.0.1.56_1.0.23. Or the http interface doesn't update if y...
Christian_R
Apr 08, 2019NETGEAR Employee Retired
Hello necrocis - Have you contacted support regarding your issue?
https://www.netgear.com/support/default.aspx
~Christian
necrocis
Apr 10, 2019Guide
~Christian
No, I reverted the router back to v1.0.1.40_1.0.22 and waiting to see if it exhibits the same symptom. I've been using the factory default WiFi password, but my own SSID (Battery Garden East). The LAN connections never drops, only WiFi. I also noticed if a device doesn't leave the wireless range it will stay connected but if it any device needs to reauthenticate it'll state invalid password. This is slighty different to what I was experiencing prior, before I had to literally change my WiFI password, with v1.0.1.56_1.0.23 a P/C corrects the issue.
- Christian_RApr 18, 2019NETGEAR Employee Retired
Hello necrocis - Thank you for the update. Curious to know how reverting back has turned out for you.
Hi Bubblecat - Have you gotten a chance to contact support for your newly purchase device? https://www.netgear.com/support/default.aspx
~Christian
- BubbleCatApr 18, 2019Star
I haven't contacted support. I have reverted my firmware about 5 days ago and my disconnects have pretty much ceased. There was one instance where I manually had to power cycle the router, but since then no drop outs or disconnects. I'll definitely will be skipping V1.0.1.56_1.0.23
- necrocisApr 18, 2019GuideZero issues since reverting, I was going to let it bake until Friday.
