Orbi
Mar 05, 2019Star
RAX80 Firmware V1.0.1.56_1.0.23 needs work!
Not even sure where to post this since my model number is RAX80. Anyway, the QOS sucks, and the DHCP must be screwed on firmware Firmware V1.0.1.56_1.0.23. Or the http interface doesn't update if y...
SereneStorm
May 01, 2019Aspirant
Same here with the firmware issues. tested multiple times.
first off with the VPN Cert download, there is a workaround. If you have Remote Managment on , turn it off.
Speeds.. with QOS, Traffic Meter, Access Control all OFF.
Firmware- V1.0.1.56_1.0.23
Down - 419
UP - 430
Firmware- V1.0.1.40_1.0.22
Down - 945
Up - 754
I have been back and forth with the firmware several times. checking different settings.
It will not work.
schumaku
May 02, 2019Guru - Experienced User
Netgear at it's best again Christian_R ChristineT - feed these issues to the people in charge please!!!
Nice find, obviously a recursion - happened several times over the years on other Netgear routers.
SereneStorm wrote:
Speeds.. with QOS, Traffic Meter, Access Control all OFF. ...
That's the no so nice part ...
