Orbi
Mar 05, 2019Star
RAX80 Firmware V1.0.1.56_1.0.23 needs work!
Not even sure where to post this since my model number is RAX80. Anyway, the QOS sucks, and the DHCP must be screwed on firmware Firmware V1.0.1.56_1.0.23. Or the http interface doesn't update if y...
jforce66
May 17, 2019Aspirant
Same problem, rolled back to the previous firmware but that has not solved the problem. Wifi craps out at least once a day, sometime 2 or 3 times in a row. No probs with wired connections. Zero problems with my previous Nighthawk 7800. Very disappointed.
- StaticLNXMay 18, 2019Star
I hope there's a fix for this
- myerswMay 19, 2019Master
Don't hold your breath based on NG firmware updates for other products. They do not seem to address the known issues. They do not seem to test for fixes to bugs reported. Seems like the firmware engineers do not have a clue as to what is going on. Would be nice if they would test a new build to see if a known problem is fixed, but they do not seem to do that. As far as I know there is no beta test for updates either. Right now it seems "the inmates are in charge of the asylum".
