Orbi
Mar 05, 2019Star
RAX80 Firmware V1.0.1.56_1.0.23 needs work!
Not even sure where to post this since my model number is RAX80. Anyway, the QOS sucks, and the DHCP must be screwed on firmware Firmware V1.0.1.56_1.0.23. Or the http interface doesn't update if y...
nytiger73
May 22, 2019Star
SereneStorm -- I am having a similar issue with speeds as you. I have 940 down with my ISP and on a wired connection the router struggles to pull 320-330. Factory reset it once, it fixed it for 3 days. It went back to doing the same thing. Last night, my 5G connection dropped, rebooted my modem and router and my speeds are in the crapper again. I called support again, they suggested I downgrade my firmware to the 1.0.1.40 revision. I did that, no improvement. So I guess I have to default the router AGAIN. Get your act together Netgear. If I could easily sell off this thing and find something better that would work, I'd sell it in a heartbeat! What is sad is the $20 router I get from my ISP works better than this thing.
SereneStorm
May 22, 2019Aspirant
I dont know about the WIFI issue myself as i use another brand of APs. but i did find after i did downgrade to the previous FW, sometimes it didnt speed back up in throughput. stayed around 400ish up and down. so i changed my third octet from 10 to 100 and back up to 930D - 800U.
