Orbi
Mar 06, 2019Star
RAX80 Firmware V1.0.1.56_1.0.23 needs work!
Not even sure where to post this since my model number is RAX80. Anyway, the QOS sucks, and the DHCP must be screwed on firmware Firmware V1.0.1.56_1.0.23. Or the http interface doesn't update if y...
Stianu89
Jun 21, 2019Tutor
Just got this router aswell and i am sad to say it has been nothing but troubble.
Wifi disconnecting.
Admin interface is unresponsable after a few hours of uptime.
Web interface is slow.
Router needs to be rebooted at least twice every day.
This needs to be fixed asap, or i am returning my unit.. and leaving a bad review for the device, wich is sad, because its one of the nicer looking prosumer routers. I expected more for this pricepoint.
- Christian_RJun 24, 2019NETGEAR Employee Retired
Hello Stianu89 - Have you gotten a chance to contact our support team? Your may activate your complimentary support using the link below.
https://www.netgear.com/support/default.aspx
~Christian
- JJsalsaJun 24, 2019Guide
RAX80: I can now report that I also downgraded my firmware to 1.0.1.40 and finally the reset function worked after that (the hard reset didn't even work properly with .56 or .58 for me). After that downgrade and re-programming the settings, the unit is FINALLY acting more stable. No reboots or crashes for a whopping 12 hours so far ;-) It still forgets all the names I put in the Attached Devices, but otherwise is working. So from my POV, .40 was the last stable release. If memory serves, the wireless speeds are not as fast as the later firmware. But it is clear that the last two releases introduced a lot of bugs and were not tested comprehensively...
- SAM_the_GAMJun 27, 2019Luminary
I finally had to downgrade to 1.0.1.40 from 1.0.1.56. Started to experience some of the bugs reported here with 1.0.1.56 after a week worth of uptime.
