The-Ark's avatar
The-Ark
Guide
Dec 20, 2020
RAX80 Firmware Version 1.0.3.102 & 1.0.3.106 Bug (Link aggregation & QoS)
I encounter problem with RAX80 Firmware Version 1.0.3.102 & 1.0.3.106
The Link aggregation (IEEE-802.3ad) function will not work if I enable the QoS.
Once I enable the QoS fiunction, Link aggregation will not function.
The only way to regain Link aggregation function is to factory resst the router.
So It shouble be a big Bug. Link aggregation uable to coexist with QoS Enable.
Need help ~
Thank you
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello The-Ark,
    May you revert back to FW v1.0.3.102 and let me know if your issue persists.
    Christian
    • Mythic82's avatar
      Mythic82
      I have had the same problem since 1.0.3 still on 1.0.2
      I tried to disable the linkaggregation but qos was stil broken
      Did factory reset before and after update but still same problem.
      Also the UI is slowing down to a crawl after a while so i dont dare to update anymore until there is no bugs left in 1.0.3
    • The-Ark's avatar
      The-Ark
      Guide
      yes, both Version 1.0.3.102 & 1.0.3.106 has same issue
      • The-Ark's avatar
        The-Ark
        Guide
        I have To roll back Version 1.0.2.76 for QoS & link aggregation to work again.
