The-Ark's avatar
The-Ark
Guide
Sep 08, 2020
RAX80 Firmware Version 1.0.3.102 Link aggregation Not working
After update RAX80 Firmware  to Version 1.0.3.102
Link aggregation Not working anymore
Can not connect to my network device using Link aggregation.
I will have to roll back to Version 1.0.2.76.
Any one know how to fix Link aggregation on new firmware?
  • After the update/issue did you try a factory reset?
    If an old setting is causing an issue, many times a reset after firmware changes can fix it.
    • The-Ark's avatar
      The-Ark
      Guide
      I did a factory reset.
      Still can not use Link aggregat
      I believe its firmware issue
      • jcax's avatar
        jcax
        Star
        No idea if this following will help you address your issue, but I hope so.
        I have upgraded from build 99 to 102. Had a bit of trouble.
        I had link aggregation working with my NAS on 99, but had trouble getting the upgrade to 102 to succeed. It kept failing with error on updating language table (see this post https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX80-New-Firmware-Out-Today/m-p/1971582/highlight/true#M12486.
        I tried doing a factory reset on 99. After that the 102 was successfully installed as part of the initialization process.
        Note that I had my NAS shut down during this whole process.
        I updated configuration of RAX80 to turn on link aggregation. Restarted the NAS. Link aggregation reestablished successfully.
