daweidu's avatar
Aug 11, 2020
rax80 Firmware Version 1.0.3.98
can not login web interface. The app is ok, password recovery does not work either.
  • michaelkenward's avatar
    michaelkenward
    Not enough to go on.
    What are you doing and where does it go wrong?
    You can help people to help you by providing the information suggested in this forum's header:
    Subject (Include model number and brief summary)
    Model (Recommended - Helps the community give the best answers)
    Body (Include additional detail including model version, firmware, OS and environment where relevant.)
    That is there for a good reason.
    • daweidu's avatar
      daweidu
      Star
      what info is missing? this is not helping user. developer needs help.
        michaelkenward
        Most of  the useful details that anyone needs to diagnose what is happening.
        What is this web interface?
        How are you trying to login?
        Which login address?
        What messages do you see when you try?
        The app is ok,
        What is this app? There is more than one.
        You get my drift?
        Start here:
        If you cannot login to your router | Answer | NETGEAR Support
        No idea who that might be.
        You should know that this community is essentially a user-to-user venue with some input from a small band of Netgear techies.
        Most of the answers come from fellow users who have no connection with Netgear. They just have a lot of collective experience and are familiar with the sort of problems that turn up here.
        But they can't work on the basis of guesswork.
        If you want "official" support then you should go through the right channels.
        Contact Us | Support | NETGEAR
