Smead
Jan 10, 2026Tutor
RAX80 firmware
Having an issue checking for firmware update via the app. appears I am at version 1.0.10.140 app keeps returning “problem checking firmware update.” any help is appreciate. ...
- Jan 10, 2026
Well, I may have solved it via sheer aggravation. Haha
rather than signing in via the terrible app, I signed in via IP on my laptop
went to the net gear site and saw update (1.0.11.148), which I downloaded. Router admin prompt did not self find the update but did apply the download manually
Not sure why self update didn’t work.
CrimpOn
Jan 10, 2026Guru - Experienced User
Smead wrote:Well, I may have solved it via sheer aggravation. Haha
If you check the "Mark as Solution" link, other will know this is no longer an active topic.
Smead
Jan 11, 2026Tutor
Thank you both. And thanks for the “marked” info
- FURRYe38Jan 12, 2026Guru - Experienced User
Sometimes NG doesn't put up newer FW for auto update for some older routers. So manually updating is a good thing.
Enjoy. 📡
