mysterioustrngr
Mar 06, 2022Aspirant
Rax80 gets low bandwidth behind ATT BG210
Good Afternoon,
I have a perplexing low bandwidth on wifi issue that doesn't seem to be solved by putting the ATT router in ip passthrough mode. I discovered I get the max download of 600 mbps but only if put the rax80 nighthawk in AP mode. If I use the nighthawk as a router , it'll get 300 mbps max.
A lot of articles suggested IP passthrough, disabling firewall features on the ATT router but this made no difference for me. It gave the nighthawk a public IP and wasn't NATing multiple times but didn't make a difference in speed.
I also tried disabling AX features, smart connect mode on the Rax80 but this lowered the speeds a lot more, down to like 60 mbps.
The nighthawk has been pretty disappointing since I first bought it with all the software bugs it has and now this issue. When I had support from netgear's limited warranty, the technician was telling me all the issues I wrote about were known but weren't being tracked anywhere that I could see and no known ETA for fix. I didn't realize about the low bandwidth issue though until recently.
What devices are you speed testing with? Wired is preferred.
What speeds are you getting at the ISP modem/router with a ethernet connected PC/laptop?
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setup- mysterioustrngrAspirant
Hi FURRYe38,
Thanks a lot for your help."What devices are you speed testing with? Wired is preferred."
Wired speed is full as expected from the rax80 behind the ATT BG210 which is about 600 Mbps up/down. It's the wireless from rax80 that's the problem.
"What Firmware version is currently loaded?"
latest available for rax80 - Firmware Version V1.0.5.132_1.0.69
"What speeds are you getting at the ISP modem/router with a ethernet connected PC/laptop? "
600 up/down
"This would be a double NAT condition which isn't recommended."
For the ATT BG210, the recommendations I saw were to put it in ip passthrough as the only option and turn off the firewall features, which I did. My public IP was passed through to the RAX80 but it didn't make any diffierence in speed over wireless. I also tried to disable all fhe features I could like AX mode and smart connect but it lowered speeds to about 70 mpbs
FURRYe38 wrote:What devices are you speed testing with? Wired is preferred.
Couple of options,
https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setup- FURRYe38Guru - Experienced User
What WiFi devices are you speed testing with?
How do you have the wifi settings configured on the router?
Good Morning,
I really appreciate everyone's help. Any other ideas or thoughts? I'm leaning toward putting this in AP mode and buy a router without a ton of issues/bugs to use as primary at this point.
Cheers
