johnwho's avatar
Oct 24, 2023
RAX80 How to disable Wi-Fi Schedule
RAX80 Firmware Version V1.0.10.140_1.0.79
GUI Language Version V1.0.10.140_2.1.46.1
Hello, my router turns off the Wi-Fi every night at 2300 and back on at 0530, as though a schedule is set, but the scheduling is not even enabled, I have enabled a schedule and set it to be off for 5 min each nigh, this did not make any difference.
After reading posts on here I am not using the netgear NTP server.
wireless signal schedule] The wireless signal is OFF, Monday, Oct 23,2023 23:00:00
wireless signal schedule] The wireless signal is ON, Tuesday, Oct 24,2023 05:30:00
  • FURRYe38's avatar
    Is there a check box that you can remove to disable it on the routers web page?
  • plemans's avatar
    Maybe its setup in the app? (don't use scheduling in the app so not sure)
    Try the old "scorched earth policy" and try a factory reset?
