Manazir
May 31, 2020Guide
RAX80 keeps droping internet connection randomly
Hi
I am using Netgear Nighthawk AX8 router for a month now. I am noticing that the router drops internet connection randomly and does not reconnect until I reboot the router. I am having this issue for quite some time. Yesterday I update the firmware to the latest V1.0.3.88_1.0.41. Still the issue is not solved yet. Same problem is repeating. My ISP is giving me a PPOE connection.
What gateway is it connected to?
Did you try factory resetting and re-installing after the update? That can help if an old setting is causing issues.
