TAI0Z
Jul 20, 2022Tutor
RAX80 No Internet Suddenly
I have had it for 2 years. Local wifi still works fine, just not getting a signal from the modem. Bypassed the router with a different one and it works fine. Tried the lastest three versions of the firmware and factory reset on each version. Swapped the cable. Could it be a bad input ethernet port? If so, how would I go about replacing said port? I don't know the first thing about how to open this thing, and Netgear charges you for even troubleshooting this. I am on the verge of just tossing this thing in the garbage and never buying a netgear product again, not because it failed, but because my avenues for repair and replacement are so awful.
I wouldn't mind paying Netgea2r to repair it or replace it with a refurbished product a partial cost of a new one, but they won't even look at it without me paying like $90.
Any ideas?
what modem/gateway is it connected to?
- TAI0ZTutor
It is a Spectrum modem, model ET2251.
Try this.
Disconnect everything from both the modem and the router. Even coax from the modem.
Wait 10 minutes.
Connect coax back to the modem and power it on.
Wait 2 minutes.
Connect cable from the modem to wan port on RAX.
Power the RAX on and give it a couple minutes.
Attempt setup on the RAx.
