Clovers
Jul 08, 2019Tutor
RAX80 randomly disconnects LAN cable
During random times on my router drops connection to LAN cables. My PS4 says LAN cable disconnected and sometimes the same to my pc. It only happens for a few seconds. I tried different cables and al...
NaibStilgar
Apr 21, 2021Star
I've been having the issue and have been working with support for some time now. I just wrote this summary for them that I think might be useful for other people so I will paste it here
My setup
Internet - Router (Mikrotik) - Router in AP mode (RAX80) (this is my desired setup)
I had (and I still have it here) another Mikrotik router as an AP that I wanted the RAX80 to replace
The issue also happens in the following setups
Internet - Router - Router in Router Mode (RAX80)
and
Internet - Router (Mikrotik) - Router in AP mode (Mikrotik) - Router in AP mode (RAX 80) (yeah that's 3 routers I tested even this way)
- The router drops connection on all of its LAN ports at the same time including the WAN port. I know that because I have 3 Windows desktops computers that drop the connection at the same time and the log shows event that looks like this
[Time synchronized with NTP server] Tuesday, Apr 20,2021 20:11:35
[Internet connected] IP address: 192.168.0.3, Tuesday, Apr 20,2021 20:11:35
These events are logged at the exact moment the PCs drop connection and indicate that the RAX80 is not only dropping the LAN connections but also the WAN connection to the parent router
- It is the RAX80 that is dropping the connection and not the internet. I know that because I ping the internal IP address of the RAX80 and when the issue happens the ping to the RAX80 is dropped as well not just the ping to Google
- It is the RAX80 because I have tested in the 3 router setup that computers connected to the RAX80 would drop connections and computers connected to the second mikrotik router would not
- It is the RAX80 because there are other people on the forums experiencing the same issue see https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX80-Short-Disconnections/m-p/1859440 and https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX80-randomly-disconnects-LAN-cable/td-p/1772176
- I have tried resetting the router, I have tried running newest and older firmware
- I have tried using the router in router mode (additional internal network). Same issue
- I have tried setting static IP addresses. Same issue
- When the disconnect happens it is just momentary. However the windows machine go into network identifying procedure (I can see this by pointing at the tray icon and seeing "Identifying"). The whole things takes less than 5 seconds and is random so I don't have much time to check other places. It seems like there is something that causes the network to reset and the actual lag is because of this renegotiation
- The wireless doesn't seem to be affected despite the fact that the WAN connection is also dropped. My hypothesis which I cannot prove is that the routers are able to negotiate between each other almost instantaneously while the Windows machines take some time so the wireless devices can't feel the drop.
I measure all this by constantly running pings to the router internal IP (in my case 192.168.0.3) with the -t option which simply runs a ping forever. When I feel the drop in some software I look at the pings and the network tray icon to confirm the issue. The ping goes into "General failure" response for a few seconds before returning to normal. (Note this is not simply Request timed out)
One thing I have not tried is changing the MTU settings because it is not available in AP mode and this is how I want the router to work ultimately and also I people on the forums have tried it to no effect. I am ready to try setting the router in router mode again and try it but I am sure it won't help
I also believe this is an issue with the model and the issue might even be for every unit and people just don't notice it or think it is their internet that is failing. Obviously I can't know for certain but there are multiple people on the forums and nobody managed to find a fix with or without help from support.
Nmouneimne
Apr 21, 2021Apprentice
A couple weeks ago I purchased an unmanaged switch and plugged that into the RAX and then plugged all my other lan cables into the swtich. So far, I have not had any drops (at least not that were noticed).
It is possible that RAX80 can only handle one lan port being used?
Does anyone else have drops with only 1 lan port being used?
- NaibStilgarApr 21, 2021Star
I've tested with 1 LAN port and seen a drop. Actually I was testing to see if the issue is with the RAX80 or something else like electricity surge so I connected 2 of my computers to another router, the RAX80 to the other router and 1 computer to the RAX80. The issue did occur only on the computer connected to the RAX80. Of course this means there were 2 LAN ports in use 1 for the Internet and 1 for the computer but if it can't handle 2 ports this way I'd say the LAN functionality is essentially useless
- sajin007Apr 21, 2021TutorI have done the same, hoping this resolved this disconnection issue.
- NmouneimneApr 21, 2021Apprentice
NaibStilgar - You said you were working with support, has Netgear appeared to acknowledge the issue?
Have they been sending you beta firmware to test?
In the past I worked with them when I had a R7800 and the Readyshare wasn't working. They would send beta firmware until they got it right. I suspect they don't do that anymore.
- rudziankouApr 21, 2021AspirantI returned this piece of crap back to the store. I bought asus rt-ax88u router. It works perfectly.
- sajin007Apr 21, 2021TutorNope, had to search on Google....one more thing I did was reduce the 5ghz speed to half - 2400mbps.
Nmouneimne no, I they got me to reset the router, confirmed the latest firmware and also got me to install older firmware.
They are not aknowledging the issue directly I mean they are aknowledging that I have a problem with the router that they need to help with not that the router is defective. I've seen the issue escalated to a third person. The first one didn't have a clue and we talked about things like resetting the router, disabling DHCP and so on and also about wireless working or not (although I made it clear that the wireless was not an issue). I then got escalated to a nice and competent guy who understood what I was talking about and we went through the motions of resetting, switching modes (router/ap) etc. I think we both knew that this wouldn't work but it seemed to be required procedure. I then (today) got escalated to the next level of support. The current step is to enable debug packet logs and I am supposed to send them when the issue happens. I am currently waiting for the issue to happen hoping that the debug logs will catch something interesting. - NmouneimneApr 21, 2021Apprentice
NaibStilgar - I appreciate your effort and please keep us in the loop if you discovery anything.
One thing I am very curious about is if anyone got a replacement router of the same model and if this replacement manifests the issue. I suspect that all units are defective and because the router is expensive a few people got it and of those who got it some are using wireless only, others thought the drops are related to the internet and so on.
- Str8UpSucioMay 21, 2021Aspirant
I've grabbed 4 replacements from (B&H, Amazon [sent the CANADA vz.] and Walmart) same exact issue constant lan drops, supprisingly I've gotten the Wi-Fi to stay super-fast, solid and stable but the LAN JESUS!!! my PS5 constantly drops connections mid games. The only difference I see in the replacements is the new ones have the fan removed and are a bit lighter in color. The LAN drops are less frequent but they are there nonetheless. I've tried a switch but its the same difference since, the switch must go MODEM > ROUTER > SWITCH. At this point since most of my devices are WIFI conncected I only run the PS5 via LAN, I was considering keeping the RAX80 if there was a way to make it so the SWITCH feeds the ROUTER.
Ultimately if I keep getting drops ill just have to revert back to my WRT3200ACM, God why did I leave Linksys (loyal for decades) for this Star Wars Imperial Shuttle.
- NaibStilgarMay 21, 2021Star
Str8UpSucio thanks for the info. So I guess we have to assume that each and every RAX80 manifests the issue. The lack of mass complaints might be related to most people using wifi, not noticing the rare lan drops in their usage or simply attributing it to bad internet connection instead of the router.
- NeckGearNatMay 21, 2021Tutor
Yeah I plug my consoles direclty into the cable modem and bypass the router now. Then use the routers wifi for the rest of the house.
- NmouneimneJun 11, 2021Apprentice
Latest Firmware 1.0.4.120_1.0.61 did not solve the issue.
- NaibStilgarJun 22, 2021Star
Update on my saga:
So they sent me a replacement router and surprise - it has exactly the same problem. Now I am convinced each and every RAX80 has it and if someone doesn't see it they are using the router in a way that the issue is not that easy to notice (for example they are only doing web browsing) or simply are using it only for wifi. The support guys are very careful not to aknowledge that directly :)
It is not clear if the issue can be repaired via firmware or that this is a hardware defect that is never going away unless they start using different parts. It is not clear if the engineering team is aware that this happens with every router or they think just some units are defective. It is not clear what they would do if they know.
So I provided them with debug logs for the new router and I am waiting for them to suggest what to do next. The guy assigned to my case is sometimes missing (vacation, ilness, I don't know) and then I get assigned another person who asks me questions that are already in the support thread. Admittedly our saga has been going for many months so the support thread is increadibly long but it is annoying. It is also annoying that I know the questions are totally unrelated to the issue. For example they asked me what my network topology is. It is not the simplest one but not that strange (ISP -> another router in Router mode -> RAX80 in AP mode -> several computers on LAN) but it is not that strange and also I point out that people here are having problems with literally the simplest topology ISP -> RAX80 -> device. I can't tell how much of this is they bull**bleep**ting me and how much is them generally not being able to follow the issue.
On the other hand the replacement procedure was very civilized, they paid the shipping and assisted me shipping the unit across Europe. They sent the replacement first. I did not have to return the original unit to the store I bought it from (which is great because I would have needed to return it via mail in another country) - GabboCHJun 22, 2021ApprenticeI'm sure Netgear know 100% it is a flaw with every router but most people don't recognise it or don't associate it with the RAX and instead think it but be the ISP model or other devices.
It's exactly the same for the Wi-Fi connection issues.
If they admitted a fault, in the US at least they would need to replace all of the hardware.
That's why the support is careful not to mention anyone else has reported the same problem & also why they have never written something in the firmware release notes mentioning either problem.
I hardwired all my tv's and consoles to get round the Wi-Fi drop out only to have the LAN issue.
Xbox is unplayable online and the tv constantly says ethernet cable disconnected. - NaibStilgarJul 04, 2021Star
OK, new findings.
So I was trying to take clean log of the issue plugged my old router, totally disconnected the RAX80 and disabled its interface. Plugged one computer and ran a ping to the router itself with some scripts to be able to easily notice when it drops. To my surprise for 2.5 days I saw no issue (possibly "bad" luck, maybe the issue will happen eventually). What I noticed however is that I couldn't get the RAX80 to work without the ethernet cable, it wouldn't give my PC an address despite the fact that it was in router mode. I had to connect the Internet cable to "wake it up" and then I was able to disconnect it and do the tests normally. That's stupid behavior but not a big deal. However in the process I noticed that if I disconnect the Internet cable all other LAN ports get disconnected and the PCs show "network cable unplugged".
So here is the hypothesis - something causes the RAX80 to think the WAN Ethernet interface is unplugged. Might be a bug in the RAX80 or something in the other devices, doesn't really matter. Maybe other models are just tolerant to this behavior. So the RAX80 disconnects ALL LAN interfaces which causes PCs to renegotiate connection, get addresses through DHCP all that jazz. Now if Netgear engineers can fix this through firmware and NOT let the LAN interfaces be restarted due to Internet cable being unplugged then maybe the issue will be mitigated. This is reasonable expectation because we know WiFi is not affected by the drops. Maybe the routers are able to reestablish the internet connection very fast in say 50ms so in practice it would be unnoticable if it didn't cause all other LAN interfaces to be restarted.
Can people who have the issue confirm that their units restart all LAN interfaces if they unplug the Internet cable? - Matt1979Jul 06, 2021AspirantTELL PEOPLE TO GO TO..
BBB.ORG
& file a complaint against netgear - NaibStilgarOct 11, 2021Star
An update with hopefully good news.
So I have been in constant contact with support for 9+ months now. After being sent replacement routers, sending debug logs and so on they sent me a special debug firmware designed to catch the issue. I sent some more logs from the debug firmware version and they said the logs indicated that my main router DHCP was misbehaving and advised using static IP addresses. I've been running in a router mode and static IP address for the RAX80 and static IP addresses for my LAN computers for a week (they use the RAX80 DHCP because of the router mode but still...) and I have seen no issue. I switched the computers to DHCP yesterday and so far I have seen no issue. This is the longest I've gone without seeing the issue and I actually run scripts to try to catch it so it should be harder to miss. I will try to switch to AP mode tomorrow and see if using the DHCP of my main router for the computers will cause the RAX80 to disconnect even if it is not using the DHCP itself.
If other people in this thread can experiment with setting a static IP address on the RAX80 Internet connection (not on the computers but on the RAX80!) and report the results that will be great. You can do that in Advanced > Setup > Internet Setup > Internet IP Address
Here are my Powershell scripts that you can use to track the issueStart-Transcript -path C:\Users\<your user>\Desktop\Pings\netgear.txt
Ping.exe -t 192.168.1.1 | ForEach {"{0} - {1}" -f (Get-Date),$_}
The first line makes the console log everything to a file.
The second runs a ping but appends a timestampStart-Transcript -path C:\Users\<your user>\Desktop\Pings\netgearFiltered.txt
Ping.exe -t 192.168.1.1 | Where {$_ -notlike "*Reply from 192.168.1.1*"} | ForEach {"{0} - {1}" -f (Get-Date),$_}
The second filters invalid replies (usually a disconnect manifests as a General failure) and adds a timestamp.
I run both scripts and look at the filtered one so I can know if something happened and then confirm in the unfiltered log. Note that you should make your computer not go to sleep or you will have some drops right before the computer goes to sleep and after it wakes up. if you see an issue you can confirm that the RAX80 log also has the issue on the corresponding time.
I believe the real issue with RAX80 is that if it encounters any problem on the Internet interface it disconnects all interfaces. It is possible that for my setup the issue is DHCP (which support says is my other router misbehaving but it might be the RAX80 mishandling it, I have no way to confirm and I do not trust them that much). In your case it might not be the DHCP so this might not solve the problem.
Looking forward to other people experimenting
