Zman112233
Mar 09, 2019Aspirant
RAX80 vs R9000 vs Whatever
Hi!
I recently upgraded my internet to Gigabit and my R7000 just isn't up to the job.
I've been looking at the RAX80 (AX6000) and the R9000 (X10). They are the same price. I'm strugglin...
michaelkenward
Mar 10, 2019Guru - Experienced User
Zman112233 wrote:
michaelkenward The R7000 just doesn't seem to have the hardward to run Gigabit speeds, especially when features are turned on.
At Gigabit speeds, QoS is going to slow down any device. It isn't needed at those speeds, and just gets in the way. Some say that anything over 300 Mbps can live without QoS.
Serious gamers prefer something like the DumaOS, which is the firmware on the XR500, a router that is actually modelled on the hardware of the R7800, but with a healthy price mark up for something that is as ugly as sin.
Most "features" will eat some processing power, but the R7800 should handle that more easily than an R7000.
The R9000 is only about $150 more than the R7800 and most of the reviews I read put it anywhere from 13-20% faster than the R7800. Not saying that difference is a game changer, but in the grand scheme of things, spending $150 extra on something I use every single day isn't a big deal.
What does "faster" mean? I take measurements like that with a trainload of salt. Real world experience is what I go by.
From what I read here, most people using an R7800 seem to get near the maximum out of Gb internet. As to wifi speeds, that is down the clients as much as the sources.
But I'm sure that a few go-fast stripes on the side won't go amiss.
myersw
Mar 10, 2019Master
R7800 is best of breed for Netgear routers. It has fewer firmware issues and has very good performance. If you want a Netgear router with minimum of issues go with the r7800. Still have mine sitting on shelf as a just in case.
With the r7800 you can install Voxel's great firmware based on Netgear OEM, plus can also install other 3rd party such as DD-WRT and Openwrt/LEDE if you like to experiment.
In short, IMHO, go with the r7800 if going Netgear.
See michaelkenward did not say anything bad. ;)
- jlockerMar 12, 2019Guide
This is my second week with the RAX80 and I can tell you this has been the best router I have owned. Fast, stable and farther reaching even with 802.11ac. With the DFS channel I am running on I am not compeating with the other 100 802.11ac routers in my condenced neigborhood.
Netgear did a great job on this 802.11ax router and getting all of my internet speed up and down out of this product.
- schumakuMar 13, 2019Guru - Experienced User
With some basic network cabling available e.g. to operate some wireless access points - go for Netgear Insight managed switch(es), WAC505 or WAC540, and the BR500. You won't look back.
Forget Netgear's consumer offerings - nice hardware, but awful firmware for at least 18 months.
