Zman112233
Mar 09, 2019Aspirant
RAX80 vs R9000 vs Whatever
Hi!
I recently upgraded my internet to Gigabit and my R7000 just isn't up to the job.
I've been looking at the RAX80 (AX6000) and the R9000 (X10). They are the same price. I'm strugglin...
Mikey-boy
Oct 13, 2019Aspirant
Hello, I just bought 3 routers, all paired up with xfinity 1000mbps and the mb8600 modem. The x6 tri band, x10 with 60 ghz and ax8 wifi 6. First off the ax8 was way slower all across the board then the x6, I'll definitelybe returning this one. Now the x10 to the x6 were very similar, however I dont have any devices that support the 60ghz so it wasn't useful for me and it costs more. I love the 2 - 5ghz band that the x6 gives you so I will most definitely stay with this one. At any given time I have 17 to 21 devices connected. I did the test with the same devices, an HP omen laptop and Note10+. One thing that i did upgrade and used for all devices was i bought a cat6 cable to connect the router to the modem to replace the cat5e they give you in the router box, and for me this really helped. Highly recommend doing this, just go get a 3' cable for $7.
Ping on all 3 was about the same, between 13 and 20ms. Upload speeds on all 3 were about the same, between 32-42mbps.
Download speed on the AX8 was AT LEAST 200mbps slower than the x6 or x10.
So currently i am connected to the X6 router with the MB8600 modem with the xfinity 1000mbps. I'll get download speeds on my note 10+ in the middle of the day between 450-650mbps. Connected with ethernet on my laptop I get about 920-954 (was the highest i was able to get).
All I can say is if this X6 ever burns up, I'll buy another one. I have coverage all over my house, everyone is connected and no lag, and the 2nd 5ghz band really helps, A LOT!!!
Do yourself a favor and save some money get the X6!
P.s. it was all tested on speedtest.net
avtella
Oct 13, 2019Prodigy
The 2nd 5Ghz band will NOT increase coverage, only throughput across the 5Ghz spectrum, sounds nice on paper but the R7800 trumps the X6 in range and overall performance even with dozens of clients thanks to a superior Qualcomm chipset, plus Broadcom chipsets like the one in the X6 haave issues with advertised extras like MU which causes performance loss rather than gain unlike on Qualcomm routers. Ive had had tthe R8000, R8500 and the R7800 so this is from experience as well. Realistically even with dozens of clients connected only a handful will be actively using a lot of bandwidth so for the average home user even power user tthe R7800 is still a better unit there are enough reviews out there, I have not seen a single one shows either the x6 or x8 ac routers beating the R7800 in 5Ghz performance at close or far ranges.
