mnarlock's avatar
mnarlock
RAX80 Wired Connection Speeds
I apologize if this is in the wrong board. I have a brand new RAX80 and am connected to an XFi modem in bridge mode. If I run speedtest from the Nighthawk GUI (advanced>Setup>QoS Setup>Take a Speedtest) I get download/upload speeds of 920Mbps/42Mbps. If I run the same speedtest from a wired PC I get 523Mbps/42Mbps. Why is there such large discrpancy in download speeds? My PC is equipped with a I219-V ethernet card.  For what it's worth, if I plug directly into the modem, the speeds wired speeds are 920Mbps. So I must conclude the Nighthawk is doing something, but what???
Firmware Version
V1.0.1.64_1.0.27
Thanks for the help.
  • There's the same issue reported for the RAX120 where the lan speed drops by about half.
    There were some suggestions that turning off QoS fixed the problem but this didn't seem to be a solution for all.
    Just another issue in the long list for the RAX devices....
    • Cookmaster301's avatar
      Cookmaster301
      Yeah I just put this router in and I get 450 hardwired and 70-90 wireless even on 5G
      On 2.4 it’s only like 25
      This thing is a turd so far
      • mnarlock's avatar
        mnarlock
        I did find that turning on/off QoS really did help. My speeds are as expected now.
