dmystic1
Dec 18, 2018Apprentice
RAX80 wishes
I'd like to see Plex and security like Trend Micro added to this device.
myersw
Dec 18, 2018Master
Buy a Asus router and you will have Trend Micro. Has to be licensed so would be upto Netgear to decide to pay for it. Probably less issues with the Asus as well.
dmystic1
Dec 19, 2018Apprentice
I guess they partnered with Bitdefender, but its not available with RAX80 yet (if ever) and its also $70 a year! https://www.netgear.com/landings/armor/?elqTrackId=41911040334d432081279174f9a158ad&elqaid=1977&elqat=2
- myerswDec 20, 2018Master
From the looks of it there may be a bit of gosh darn graphic, but I think what you are really doing is installing Bitdefender on all devices for $70. Depending on number of devices you have it might be a good price if that is the product you want. I run Bitdefender on my PC's and MAC laptop. Works well. They also sell a box that sits between the modem and the router to block everything early. Very limited number of routers and has been. Personally I would prefer Netgear focus on getting good solid firmware for all routers, then add in bells and whistles.
- dmystic1Dec 20, 2018Apprentice
It says it installs on the router.
Yes it does, but this suggests installing also on devices.
https://www.netgear.com/landings/armor/#endpoint
At least that is how I read it. Only way I can see other then using VPN to home network to protect would be on devices.
