ky123mt
Aug 18, 2020Follower
rax80
I just did firmware update everything seamed to go ok. I have wifi everything is normal but I can not log into the netgear app once I log into app it shows the router using "connect via anywhere access
I see the router RAX80 shows correct serial number but says DISCONNECTED
how can get access to it?
- Christian_RNETGEAR Employee Retired
Hi ky123mt,
May you reinstall the Nighthawk app and power cycle your router.
Thanks,
Christian
