ndanger69
Sep 28, 2020Tutor
RAX80/EAX80 stops responding
| Hardware Version | RAX80 |
| Firmware Version | V1.0.3.102_1.0.48 |
| GUI Language Version | V1.0.3.102_2.1.46.1 |
| CPU Load | CPU1: 2.88% CPU2: 1.70% CPU3: 1.76% CPU4: 1.76% |
| Memory Usage (Used/Total) | 420MB/882MB |
| Flash Usage (Used/Total) | 52.00MB/512.00MB |
| Network Session (Active/Total) | 3917/65535 |
| System Uptime | 0 days 13:25:23 |
About once every 36 - 48 hours my router will stop responding and will lock up so that you cannot get to the web interface. I have to power cycle the device to get it to come back. When this happens, I can look at the logs and see the following.
[Time synchronized with NTP server] Monday, Sep 28,2020 02:47:06
Wednesday, Dec 31,1969 12:00:00
Is anyone seeing anything similar or have any ideas as to what to try? It almost feels like a memory leak, but the memory usage as detailed above is not terrible.
Also, is there a way to setup a scheduled reboot or is there a way that I can telnet into the system via a script activated via a CRON job?
- Christian_RNETGEAR Employee Retired
ndanger69,
Did this occur recently? May you revert to the previous firmware version and let us know of any changes.
https://kb.netgear.com/000061902/RAX80-Firmware-Version-1-0-3-88
Christian
This has been occurring for at least the last 3 - 4 firmware revisions so I doubt that rolling back is going to resolve this issue.
I too am running the latest firmware revision on the RAX80 (V1.0.3.102_1.0.48). I can usually expect a complete crash and restart at least once a day. There is something fundamentally wrong in the firmware that is causing this issue. I too see entries like this in the logs after the crash:
[DoS attack: Fraggle Attack] from source 24.158.80.1,port 67 Thursday, Oct 08,2020 07:33:28
[DoS attack: Fraggle Attack] from source 24.158.80.1,port 67 Thursday, Oct 08,2020 07:33:07
[DoS attack: Fraggle Attack] from source 24.158.80.1,port 67 Thursday, Oct 08,2020 07:32:46
[DoS attack: Fraggle Attack] from source 24.158.80.1,port 67 Thursday, Oct 08,2020 07:32:28
[DoS attack: Fraggle Attack] from source 24.158.80.1,port 67 Thursday, Oct 08,2020 07:32:07
[DoS attack: Fraggle Attack] from source 24.158.80.1,port 67 Thursday, Oct 08,2020 07:31:46
[DoS attack: Fraggle Attack] from source 24.158.80.1,port 67 Thursday, Oct 08,2020 07:31:27
[DoS attack: Fraggle Attack] from source 24.158.80.1,port 67 Thursday, Oct 08,2020 07:31:06
Wednesday, Dec 31,1969 19:00:00
Wednesday, Dec 31,1969 19:00:00Great that it is blocking the attack, but it would appear to me there is a buffer overflow problem somewhere in the firmware and it has been there through the last several firmware updates. Netgear, it would be great if you provided some sort of tool/utility that we could help you solve this. Similiar to the crash reports that Apple/Microsoft allow you to send.
- 880911ckAspirant
I thought it was just me!!!
This has been happening to me to forever now. This router is always locking up and I constantly have to reset it.
