oboeadam
Mar 05, 2025Aspirant
RAXE300 No internet
Hi everyone,
I'm having what looks like the same problem as a few people with this product. The router works fine until suddenly the internet LED is solid amber. Xfinity reporting no outages or problems on the ISP front.
Steps so far:
Power cycle/reboot both Modem (also Netgear) and Router multiple times, turned off/rebooted all computers connected.
Updated Firmware to 1.0.8.64
I'm hitting a wall as to what to try next. Product is less than a year old, but out of the 3 month tech support window. I'd appreciate any advice. Thanks!
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- oboeadamAspirant
Solved:
Did the full factory reset and we're back up.
Enjoy. 📡
