Tassadar
Oct 06, 2025Aspirant
RAXE500 - GRC shows port scans as closed instead of stealth since last firmware
Initially, the router was always showed all port scans as "stealth" on grc.com>shieldsUP. Since the new firmware (1.2.14.114), almost all port scans show up as "closed" (which is not ideal). Is thi...
- Oct 10, 2025
CrimpOn, your suggestion was the perfect solution, now all port are reporting stealth. Thank you a ton friend.
CrimpOn
Oct 06, 2025Guru - Experienced User
There have been discussions about this which appear to indicate that the new Protection Engine has changed the router firewall from ignoring connection attempts (i.e. "stealth") to rejecting them (i.e. "closed") Users report that disabling Protection Engine returns the behavior to the previous method (i.e. "stealth")
This leads to the conclusion that users have a definite choice:
- Enable Protection Engine, for whatever benefit it has and accept that ports appear "closed" rather than "stealth", or
- Not enable Protection Engine and give up (whatever the hell it does).
