Tassadar
Oct 06, 2025Aspirant
RAXE500 - GRC shows port scans as closed instead of stealth since last firmware
Initially, the router was always showed all port scans as "stealth" on grc.com>shieldsUP. Since the new firmware (1.2.14.114), almost all port scans show up as "closed" (which is not ideal). Is thi...
- Oct 10, 2025
CrimpOn, your suggestion was the perfect solution, now all port are reporting stealth. Thank you a ton friend.
Tassadar
Oct 10, 2025Aspirant
