madger's avatar
madger
Tutor
Oct 25, 2022
RAXE500 160Mhz
How do i enable 160Mhz channels ?
  • plemans's avatar
    When its set to "up to 4800mbps" in the wifi settings, thats 160mhz wide
    • madger's avatar
      madger
      Tutor
      When i go to the drop down for wifi 6 channel select the actual 160ghz channels are unavailable, only 80Mhz channels?
      • plemans's avatar
        Got a screen snip?
        Also what region are you in?
