kiddycone
Sep 07, 2026Aspirant
RAXE500 2.4 band doesn't work at all, only 5G.
I've tried changing the channels; there are no new devices or even neighborhood networks that I can tell. For devices that can use 5G, the devices use that. For ones that can't, such as the print...
- Sep 09, 2026
Factory reset worked. Everything already seemed to match the above, so not sure how that fixed it. But, all good.
FrumpyGrandpa
Sep 07, 2026Luminary
kiddycone wrote:The wifi button on it is blinking
There are three WiFi LED's, correct? It is the 2.4G WiFi LED that is blinking. (which, of course, is not something it is supposed to do)
This may be a time to perform a Factory Reset.
