kiddycone
Sep 07, 2026Aspirant
RAXE500 2.4 band doesn't work at all, only 5G.
I've tried changing the channels; there are no new devices or even neighborhood networks that I can tell. For devices that can use 5G, the devices use that. For ones that can't, such as the print...
- Sep 09, 2026
Factory reset worked. Everything already seemed to match the above, so not sure how that fixed it. But, all good.
FrumpyGrandpa
Sep 08, 2026Luminary
Have you tried:
- Reset the printer
- Connect the printer using the WPS button (page 20 of the user manual)
