kiddycone
Sep 07, 2026Aspirant
RAXE500 2.4 band doesn't work at all, only 5G.
I've tried changing the channels; there are no new devices or even neighborhood networks that I can tell. For devices that can use 5G, the devices use that. For ones that can't, such as the print...
- Sep 09, 2026
Factory reset worked. Everything already seemed to match the above, so not sure how that fixed it. But, all good.
kiddycone
Sep 09, 2026Aspirant
- FURRYe38Sep 09, 2026Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
