perseid
Oct 09, 2022Aspirant
RAXE500 displays as a drive under Network Locations/Windows Explorer
Randomly I see the RAXE500 show up as a folder under Network Locations in Windows Explorer and if I click on it a bunch of folders open up as shown in attached picture. Any way to disable this sharing? Thanks
If you log in through the router and go to advanced--->usb functions---> and then uncheck the readyshare features, does that disable it for you?
Do you have a usb drive connected to it?
