dunc101
Dec 18, 2025Follower
RAXE500 ethernet port 3 failure?
Hi all - help please! Ive been more than happily using my RAXE500 a while now, and have enjoyed utilising link aggregation to my NAS using ethernet ports 3 and 4. But I noticed recently my NAS r...
Dec 18, 2025Guru - Experienced User
Swap LAN cables?
CAT6 is recommended.
Power OFF the router and NAS then back ON?
Disable LAG then reenabled it?
Factory reset the RAXE router and setup from scratch?
What FW version is loaded on the router?
FURRYe38 wrote:Power OFF the router and NAS then back ON?
Do this first.
If nothing changes, disable the LAG, and test the ethernet port by itself. Ideally use a different client (for example, a PC with the wifi turned off).
