SniperStorm
May 03, 2022Tutor
RAXE500 Overriding my Static IP Addresses.
I have a RAXE500 Router. I have several devices on my network that have a static ip address. IE 192.168.1.18 and are wired. Lets say for example I reboot my router for whatever reason. My router will sometimes assign any of my other devices that are set up as a dynamic ip and get their ip address from the router. So my router will just assign another device that ip. And not matter how many times I reboot the router will just not correct itself. So the device with the static ip will not work. I have no idea how to stop this from happening. I turn off the device that it assigns the ip to then reboot and it will be ok. Then if a reboot happens it may do it to another device on the network that is set up as static. Any ideas how to fix it?
Hi SniperStorm ,
What is your wire device ? PC or NAS ?
Sometime device won't respond ARP so cause this issue happened.Or you can use DHCP reservation function.
I'll echo what CD_router_888 said and say use the reservation function.
I've been using it on my RAXE and its worked fine for address reservations.
