MLB999
May 19, 2025Guide
RAXE500 port forwarding problem
Greetings, I've seen community messages about accessing PLEX media server via port 32400 but they are years old and much earlier routers. My access to my PLEX media server on my LAN stopped yesterda...
- May 20, 2025
Thanks for your help. This is now solved. Turned out not to be a problem with Netgear port access. I had to completely remove Plex media server app and all ts folders from the NAS. I have reinstalled the media server app and I am now rebuilding the libraries. A process that will probably take 24 hours or more. I'm guessing a file or setting corruption somewhere as a result of the electricity problems.
MLB999
May 21, 2025Guide
Many thanks for that advice plemans. I do have an old Windows PC and might have a play with that.
- plemansMay 22, 2025Guru - Experienced User
This site was great for looking at older pc's to see if the built in CPU could transcode as well as what gpu might be beneficial to add.
https://www.elpamsoft.com/?p=Plex-Hardware-Transcoding
