GolfDude's avatar
GolfDude
Raxe500 Readyshare stopped working
ive had an extenral drive setup with readyshare for a while now, but now the rotuer isnt seeing the drive anymore, it says NO DRIVE, and i cant connect to it.. if i plug it in via usb to my pc, everything is there and fine.. so its not a drive issue.. what is causing this sudden NO DRIVE issue on the router?
  • FURRYe38's avatar
    Do other external drivers work with the router?
    Has the Router and USB drive been fully powered OFF for 1 minute then back ON?
    • GolfDude's avatar
      GolfDude
      i tried attaching another drive i actually just got this week, and it also shows as no drive found  on the router for readyshare.. both dont show up,
      • FURRYe38's avatar
        Try a factory reset on the Router with the USB drive disconnected from the router. Complete the setup then power OFF the router. Connect the drive and turn ON the router. See if the drive appears.
