Federico-Venier's avatar
Nov 16, 2022
RAXE500: should I buy or does it keep disconnecting from Internet?
if it is known to be buggy, I prefer not to buy to then return to Amazon.
PLEASE HINTS
My current D7000 (=R7000+Modem) FW V1.0.1.84_1.0.1 connected to an external modem at 1Gb/s, keeps disconnecting from internet every day. Devices remain connected and they communicate each other, but to re-establish Internet connectivity I have to reboot?
  • FURRYe38's avatar
    Try bridging the D7000 modem to put it in modem only mode.
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    • Federico-Venier's avatar
      Federico-Venier
      I need to use it as a router, and "router only" is not available
      LAN should be good. Anyway even disconnecting and reconnecting does not fix it.
      What's your feeling for the RAXE500? I have a 1Gb/s fiber connection and about 15-20 devices
      • FURRYe38's avatar
        So you need to use the modem in router mode? The D7000 does have a bridge mode. If so, then you might turn OFF the D7000 wifi radios and use the modems DMZ for the RAXE router then.
