Deepthi_
Mar 29, 2023Follower
RAXE500 WIFI 6E Router telnet console help
Hi,
I was trying to configure an SSID with WPA3 security mode via router command line interface, but I am getting 'wl unsupported' error while issuing the following commands:
wl -i wl2 sae_pwe_hnp_enable 0
wl -i wl2 sae_password "1234567890"
I am able to do the same through router web UI,but not from CLI.
Where can I find more info on supported wl commands for this device (RAXE500)?
1 Reply
- KitsapMaster
Deepthi_ wrote:Hi,
wl -i wl2 sae_password "1234567890"I am able to do the same through router web UI,but not from CLI.
You might get some responses to your question over on the Small Net Builders forum. Try here:
https://www.snbforums.com/forums/netgear-ax-wireless-wi-fi-6-6e.58/
