tcpwpb
Apr 29, 2021Aspirant
RBR850 unable to activate Netgear Armor
I have an Orbi for which I want to activate the Netgear Armor security. I'm unable to do this as the "free trial" feature can't be cleared and it gives an error. I don't want to pay for the subscription if this error can't be cleared. I prefer to avoid resetting the router as it took 4 hours to re-establish the setup when I had to do a previous reset.
Product details
Orbi Rbr850
firmware V3.2.18.1
Thanks,
- Christian_RNETGEAR Employee Retired
Hello tcpqpb,
Welcome to the community! May you send me a private message confirming your email address and router serial number.
Thanks,Christian
- tcpwpbAspirant
Subscribing was never the issue. The issue was with the Orbi and the ability to have the Armor security feature enabled after I had subscribed. The download and install was failing. I was able to get the feature enabled by repeatedly performing a device reset. I had to reset the device 3-4 times with the full setup steps in order for three Armor download to the Orbi. Quite frustrating and a waste of time. But at last it finally worked.
