brad99superd
Feb 13, 2025Initiate
Re: NETGEAR_RAX43v2 will not update to this Version of firmware 1.1.4.28!
Hey guys, any updates to this? Support has been trying to get this firmware updated and no luck. We've tried a factory reset, updating manually. No prevail!!
What is happening when you try to update the router?
How are you trying to update the router? Manually? Unpacking the .zip file?
What browser are you using? Try a different browser?
What FW version is currently loaded on the router?
- brad99superdInitiate
Good questions thanks for your response!
What is happening when you try to update the router? It updated to the version previous, for the newest version it's saying that the firmware is not compatible with my router.
How are you trying to update the router? Manually? Unpacking the .zip file? Tried all of the above, same results, got a call in to Netgear.....support and I reset my router to factory reset and still same issue. They have tried updating it as well with their steps (in which are the same as I tried)
What browser are you using? Try a different browser? Edge and Chrome (we did both)
Firmware Update AssistantNew firmware is found. Do you want to update the firmware? (Yes) (No) Current Firmware Version 1.1.3.18 New Firmware Version 1.1.4.28 I got a call back from the vendor, they believe it's an issue with the firmware, clearly most of us are having the issue. They are going to get back to me. (just an update)
Thanks for your response!
- CJ_LIUAspirant
Hi brad99superd,
I just encountered the same issue. Have you get your firmware updated? Or is your router still running 1.1.3.18? Thank you!
