ajb2
Aug 11, 2024Follower
Re: Persistent Issues with Netgear RAX43 5GHz Network and Log Settings
I am having a similar problem starting a couple of weeks ago. Everything is fine then the router stops broadcasting 5G. Reboot fixes it but it's now happening at least once per day. Firmware version is V1.0.16.132_2.0.92. I can't tell when this was updated (I have auto update on) but I don't think it is recent.
1 Reply
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-messageHas a factory reset and setup from scratch been performed since last FW update?
