oobymach
Jul 08, 2025Follower
Re: RAX-70 second 5 Ghz band drops randomly
I know I'm late to reply but I just bought one of these routers (rax70) and had same issue (it was disconnecting after about a minute and only on the fast 5ghz network). My resolution was to do 3 ...
Jul 09, 2025Guru - Experienced User
Channel 40 has always worked great on my RAX routers.
Also there is newer FW available for the RAX70: Nighthawk Firmware Releases | NETGEAR Communities
